larger diameter cat connections?
Old Oct 19, 2004 | 01:02 PM
skippyp's Avatar
skippyp
So.... all these big exhausts are having to go through the cat... 3" pipe at the inlet&outlet. I keep hearing that the cat itself flows great, but there is still the restriction at the connections. So, boundary theory aside, what real benefit is there with larger diameter exhast pre-cat? (more noise?) Does ford make a cat with larger pipe connections? or is there an accepted aftermarket cat for this purpose?
oh- and if your response is to delete the cat, save it.
Old Oct 19, 2004 | 03:03 PM
jasfaa's Avatar
jasfaa
The inlet and outlet is a 3.5 inch diameter. As for the down pipe, it too is 3 to 3.5" depending on the bend. With a 4" downpipe there is less restriction right on the other side of the turbo which helps because there is more room for the exhaust to escape than with the 3.5" downpipe that is stock since it has so many crimped bends. Also, the cat will need to be deleted at some point or replaced because diesels do nothing but collect soot quickly which is the big reason people want to remove them. I left mine on because I could see right through it still. I have also read that you can clean them out by blowing (with air) the stuff it collects if you want to. Never tried it and I find it hard to really believe.
Old Oct 19, 2004 | 03:11 PM
jdadamsjr's Avatar
jdadamsjr
You can also do what I asked my muffler guy to do....
knowing the the main part of the cat is larger than 4 inches...
On my 03 6.0L X the cat inlet and outlet both flare a LOT...
Have them cut the ends to match up with the inlet pipe and outlet pipe...
the front of the cat was cut large enough to allow the tailpipe to fit INSIDE the cat inlet and then welded....
the rear of the cat was cut to as large an opening as possible but still let the cat fit INSIDE the tailpipe and welded there...
flows pretty well enough for ME
Old Oct 20, 2004 | 05:19 AM
t_j82's Avatar
t_j82
I am going back to a state that does not check for such things as emissions equipment. I have an '05 6.0 and am wondering do I really need to keep the cat on? I would prefer to go to the lightly muffled 4" no cat.
Old Oct 20, 2004 | 06:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
The CAT does not hurt your HP...so why get rid of it.....in the pst they used to...not now
Old Oct 20, 2004 | 06:22 AM
jdadamsjr's Avatar
jdadamsjr
And, in case you didn't realize it, it is a FEDERAL law regarding tampering with the emissions so the state you go to may not "test" for that, but you can still be ticketed!
and like stated b4, many have seen little or no difference with performance or fuelage...
And, OBTW, other sites won't even allow you to discuss this since it is illegal
Old Oct 20, 2004 | 01:04 PM
t_j82's Avatar
t_j82
Originally Posted by Tim Lamkin
The CAT does not hurt your HP...so why get rid of it.....in the past they used to...not now
Thanks Tim, since it doesn't hurt HP I'll leave it alone...
