Leaf Springs
Old Oct 19, 2004 | 11:22 AM
MooseHead Rider's Avatar
MooseHead Rider
Leaf Springs
Have any of you experienced your rear leaf springs breaking? I have a 2000 F350 and I noticed last night that both rear leafs have some pieces missing. I don't carry anything that heavy in it and while I do tow things it is not something I do with any consistency. Very strange and costly. Around 600 to replace them. SIGH..........
Bob
Old Oct 19, 2004 | 11:27 AM
Max1775's Avatar
Max1775
Wow, never had that problem except on trailers. That truck isn't that old, are you the first owner? Sounds like spring fatigue due to overloading.
Old Oct 19, 2004 | 11:29 AM
Max1775's Avatar
Max1775
Are you get a lot of axle wrap? Oversized tires and hard acceleration? Same springs on both sides?
MooseHead Rider
I am the first owner and I can say that I have never overloaded it so it's got me. I have been driving some rough roads but that should not have caused it.
They are the same springs, original in fact. Not sure what you mean by axle wrap.
Bob
Old Oct 19, 2004 | 11:31 AM
Max1775's Avatar
Max1775
That's very strange, did the dealer have an explanation? Also, check for aftermarket spring packs, better quality and much cheaper I would think.
Old Oct 19, 2004 | 11:36 AM
MooseHead Rider
They haven't seen it yet. I am going to ask them though. The place I go to has been very good to me so if there is something wrong I am sure they will take care of me.
I called a place that does nothing but springs for trucks and they ended up being more expensive than the dealer. I was shocked because stuff at the dealers is always more. Maybe they are catching on............
Old Oct 19, 2004 | 11:38 AM
Max1775's Avatar
Max1775
Spring wrap is the axle twisting as the truck accelerates. It causes the leaf springs to flex up on one side and down on the other side of the axle, much like holding your arms out in a doorway and turning your body. Your arms stay still, but your shoulders pivot and allow your body to move. Springs will flex at the axle and allow the axle to move.
Old Oct 19, 2004 | 11:39 AM
Max1775's Avatar
Max1775
Good luck and post your findings if you get anymore info.
Jbart1968
Jan 10, 2017 11:53 AM
BLDTruth
May 25, 2016 04:33 PM
Mach1394
Aug 24, 2015 08:51 AM
Hometown Pride
16
Sep 2, 2009 04:13 PM
geoaigel
Dec 18, 2002 06:42 PM
