speedometer cable help
Old Oct 19, 2004 | 10:37 AM
kenmaraz's Avatar
kenmaraz
Hello, I'm still building up my '53 F100. I've installed VDO gauges, I have a C6 Trans, and the original speedo cable and housing from the C6. My question is, the Speedo cable assembly seems to have a clip on end for attaching to the speedometer, that won't stay on the VDO gauge, which appears to be set up for a screw on attachment. Anybody encounter this? And can I somehow splice the cable housing to put on a screw on end? Thanks again, Ken
Old Oct 19, 2004 | 09:05 PM
manglass's Avatar
manglass
Doesn't the C-6 have a screw on end at the transmission? If so, the original cable from the truck will probably work.
Lou
Old Oct 20, 2004 | 07:52 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Ken,
If you are working with screw-on ends on both ends, check with NAPA. They have a universal speedometer cable and housing that will work. Also, 55-57 Chevys and many other older vehicles before 1970 or so used this type of cable. I used a 57 Chevy cable in a 29 Ford with a TH350 and VDO speedometer and it worked fine.
Vern
Old Oct 20, 2004 | 02:10 PM
kenmaraz's Avatar
kenmaraz
Thanks for the help, greatly appreciate it
Ken
Old Oct 27, 2004 | 05:23 PM
twofast4u's Avatar
twofast4u
Thanks. I'm a NEW poster and I am missing a speedo cable. Now I will go to NAPA.
