Sponsored by: Real Truck
Mobil 1/Shell Rotella
Old Oct 19, 2004 | 09:31 AM
sammy.says's Avatar
sammy.says
Which one is best one to use? Does Shell make a synthetic oil? If so where can you get it and how does it compare in price with Mobil 1? Thankls for any input
Old Oct 19, 2004 | 09:36 AM
V10MARS's Avatar
V10MARS
They are both good. What are you using it in?
Old Oct 19, 2004 | 09:42 AM
sammy.says's Avatar
sammy.says
I want to start using it in my 2000 F350 Diesel. I was just wondering which one is the best and the price of each.
Old Oct 19, 2004 | 11:11 AM
slc10844's Avatar
slc10844
If you use Mobil get Delvac 1 or Mobil 1 Truck & SUV. Mobil 1 isn't formulated for diesel application. Use an oil with CH-4 or CI-4 rating. I use Rotella T Synthetic. Wal Mart carries a good selection of oils, including Shell and Mobil products, at good prices. They also carry Motorcraft oil filters.
Old Oct 19, 2004 | 12:32 PM
sammy.says's Avatar
sammy.says
What weight of rotella synthetic oil? I have only seen 10w-40w in rotella synthetic.
Old Oct 19, 2004 | 03:27 PM
Bruce S's Avatar
Bruce S
I was told to use the 10-40 grade oil. I used the Rotella regular in my new van with 6.0 for the first oil change. When I called the dealership and was told how much they wanted, I did it myself. A little over $40. with filter. They wanted $89.95 + tax. Yeh, Right.
Bruce
Old Oct 19, 2004 | 06:12 PM
V10MARS's Avatar
V10MARS
The Rotella syn 10w40 will be just fine. Has been used by many heavy hualers for years.
Old Oct 19, 2004 | 07:55 PM
Bruce S's Avatar
Bruce S
Would the synthetic oil be better to use in the new 6.0 diesel? Would the syn go against the Ford warrantee.
I drove BIG truck for 20 years and we never used synthetic oil. Put a few hundred thousand miles on them diesels. Is there an advantage in these smaller engines?
Bruce
Old Oct 19, 2004 | 10:21 PM
V10MARS's Avatar
V10MARS
Bruce
Yes. These engine are shipped with syn-blend oil. Your big rig made 350 Hp/1200ftlb torque@1800rpm. Your 6.0 needs about 3000 rpm for max power. (not sure of the power curve at the moment). Higher rpm and operating temp(hepls meet EPA numbers) are the main issues....
Old Oct 19, 2004 | 10:54 PM
Bruce S's Avatar
Bruce S
Thanks, I'll think about that next oil change.
Old Oct 20, 2004 | 12:23 AM
Pikachu's Avatar
Pikachu
I ran Mobil Delvac1 synthetic in my tractor. Cat 3406E 475 hp. Gained about 8% fuel economy, extended the drain intervals to nearly 100,000 miles, and used less oil in the meantime.
Old Oct 20, 2004 | 04:00 AM
slc10844's Avatar
slc10844
FYI-I haven't been able to find anything to the contrary, but Rotella 10w-40 synthetic is a synthetic blend motor oil not a full synthetic. Rotella T Full Synthetic 5w-40, in the blue jug, is the one to use.
