crew cab engine swap
Old Oct 19, 2004 | 08:19 AM
isaz's Avatar
isaz
i have a question about what it will take to swap my 400 engine out
and install a 460?What modifications would i have to do or what mounts will i need?The 460 is currently in a 76 2x4 crew cab will all brackets work?I will be installing it into a 1979 4x4 crewcab.
Anyhelp will be appreciated.
Thank You....
Old Oct 21, 2004 | 04:30 PM
Mike G's Avatar
Mike G
I believe the engine stands/perches from your 76 will fit right onto the 79 frame, pull the complete unit with tranny out and set it up on the 79 to see what you get....
--Mike
Old Oct 26, 2004 | 11:25 AM
isaz's Avatar
isaz
I think i read somewhere where there is more to it than that i heard that you
have to change all the brackets as well?Because it is a 4x4.
