How accurate are electrical aftermarket gauges? what does it take to install these? Which would be easier to install mechanical or electrical? i think the electrical would be easier.
Watch out for the mechanical oil pressure gauges. Many of them have a thin nylon line that can get abraded and leak. Some of them let go suddenly. Hot oil spraying you is not pleasant (severe burns) and it makes a terrible mess in the interior, at least what's left of it after the crash. If the line breaks outside the cab in the engine compartment you can empty the crankcase and destroy the engine before you notice. Probably one of the reasons the OEMs use electric.
-Just my 2 cents from seeing it happen.
i have heard about that happening. what is all involved with installing electrical gauges? and are they pretty accurate?
If the line breaks outside the cab in the engine compartment you can empty the crankcase and destroy the engine before you notice. Probably one of the reasons the OEMs use electric.-Just my 2 cents from seeing it happen.
yeah, when I was in high school, I was on the way to school one day, when
the engine in my old Jeep J-10 truck started knocking. Found later the line had gotten hot, and a hole had formed in it, in five mmiles almost all my oil had squirted out, ended up having to rebuild the engine, with new crank, 3 new rods, and all the valves gettin' replaced, wasn't cheap, either
I know someone who grenaded a $10,000 diesel engine with a cheap mechanical oil pressure guage that way.
To install electrical guages you will need a sender (probably included with the guage but check the fine print), wire, and a source for voltage, lights and ground. You may need to drill a hole in the firewall and use a grommet to protect the wire from shorting
The oil pressure line on my truck busted under the hood, but I'm **** about watching the gauges, and I saw no oil pressure, pulled over immediately, and found it out. They also sell copper oil pressure lines for a few bucks that seem more durable.
OK, well my question is this....if the line for a mechanical oil pressure gauge leaks....won't it lower the pressure reading and wouldn't you notice the gauge tellin' ya theres no oil?
That's correct, if the leak is bad enough & you're watching. I installed an electric Autometer trans. temp gauge on my 250, works great. I have friends at the track using the electric oil pressure gauges, haven't heard any problems with them. Saves worrying about line breakage, etc. I've had several mechanical temperature gauges fail, usually breaks at engine, probably from removing, engine pulls, etc.
