347 stroker
Old Oct 18, 2004 | 10:23 PM
Fordever2's Avatar
Fordever2
347 stroker
I was wondering how much power a 347 stroker kit would boost me up there? any help would be thankfull for
Old Oct 18, 2004 | 11:05 PM
fordbeast_80's Avatar
fordbeast_80
Depending on heads and cam, you can make all kind's of power with a 347.
Old Oct 19, 2004 | 12:18 AM
Sanders's Avatar
Sanders
I doing a build now on a 302. The block is at machine shop now getting balanced and bored out. I don't know if you know but 347's have a tendancy to crack the block right down the middle. I was going to go with a 347 but decided on the 331 instead. It makes about the same hp but a shade less torque. It has cost me some serious money so far on parts.
I have a set of World Roush 200 heads with 2.02/1.6 valves, I retro fit my block with roller lifters and installed a set of roller rockers on the heads. All the internals are forged, crank, rods, and pistons(flat tops with valve reliefs). 10:1 compression. I have a Lunati 290/300 cam with a lift of .540/.560. Edelbrock intake, Holley 570, MSD dist., 6a box and coil, long tube headers and dual Flowmasters. Also electric fans to free up hp.
This is going to be put in a 1968 F100 with a beefed up C4, and a 3.70 posi rearend. The predictions from the local speed shop are, that it's going to be making around 450 ponies, not bad for an old farm truck.
Serious power can be made from a small block. I'll let you know how it runs and how it's street manners are, when the motor gets done. Give me a week or so.
Sanders
It's all in the heads and making sure your components match.
Old Oct 19, 2004 | 03:28 PM
1low50's Avatar
1low50
I wanted to get one thing clear, what is the difference between the 331 and the 347? From what I have read and have been told the only real difference is yeah the cubes, but that is in the bore of the block. Please someone correct me if I am worng because I just wanna know so I can decide to stay at a built 306 or go higher. Thanks
Old Oct 24, 2004 | 05:38 PM
Fordever2's Avatar
Fordever2
nobody has answerd my problem yet i have had people ask me things but never help get to the bottom of the situation. plz help me out
Old Oct 24, 2004 | 06:54 PM
fordinlinesix's Avatar
fordinlinesix
331:
Crank: 3.250" stroke
Rod Length: 5.955"
Bore: 4.030"(.030 over)
347:
Crank: 3.400" stroke
Rod Length: 5.400" stroke
*These are for most kits, there are some kits that change the length of the rods and crank for the 347. I would personally go for the 331. I have a 347 in my '68 F100 and it uses some oil, but I've heard from other people this is normal for a 347. Also, you have to notch the bottom of the cylinder walls for a 347 for the rod to clear the skirt of the cylinder wall, so from experience, I would just go with the 331, less headaches
Old Oct 24, 2004 | 07:01 PM
fordinlinesix
A 347 will make roughly 400hp and 450 ft lb's of torque.
Old Oct 24, 2004 | 08:17 PM
Fordever2's Avatar
Fordever2
well how much is a 331 if it is better.
Old Oct 24, 2004 | 08:25 PM
68torino's Avatar
68torino
Lot's of people are trying to help you, if you had information on what camshaft, what heads, compresion ratio, and intake you are going to use we could help you out more, the power an engine makes is dependent on all of theses factors.
I could build a 331 or 347, but if I put stock heads, and stock cam, and manifold's on it it is not going to live up to it's potential.
Old Oct 24, 2004 | 08:27 PM
Fordever2's Avatar
Fordever2
well its all stock rite now. can u tell me wat the best combo is then?plz thank u
Old Oct 24, 2004 | 09:25 PM
Sanders's Avatar
Sanders
What I posted above is a good setup for a 331. A slightly smaller cam will give you a litlle bit more torque.
Sanders
Old Oct 25, 2004 | 11:52 PM
Fordever2's Avatar
Fordever2
thanks so do u have a program like dyno 2003 or sumthin?
how much does it cost and where can i find it?
Old Oct 30, 2004 | 10:47 AM
kopp16387's Avatar
kopp16387
i am goin a 347 stroker and i was wonderin what kind of numbers i would get and what rods i need to get sould i rubild the heads for more power
everything is will have
stock 289 heads ported
cam with a dur of 285/325 and a 655/655 lift
rollerrockers
afftermarket intake
850cfm holly carb
thanks
