t-case gasket
Old Oct 18, 2004 | 09:17 PM
natron343's Avatar
natron343
Red face t-case gasket
on my 91 f150 im putting in a tcase(1356BW slip yoke, elec shift). is there a gasket/seal from the tranny to the case? if there is a gasket, do you need a gasket or can you use form a gasket or some sort of sealant. any help!?
Old Oct 18, 2004 | 10:06 PM
smoke n tires's Avatar
smoke n tires
i think its just a lip seal similar to a pinion or output shaft seal. there is usaully one on the t case and one on the trans.
Old Oct 19, 2004 | 10:04 AM
FordPerf300's Avatar
FordPerf300
Some Red RTV will be fine between the two.
