95 I-6 13mpg
Old Oct 18, 2004 | 08:53 PM
19903024x4's Avatar
19903024x4
Unhappy 95 I-6 13mpg
I have a 95 f-150...I6..5spd 4x4......gets about 13 mpg....this can't be normal...i changed the o2 sensor and the plugs.....cap...rotor and wires are next.....what are some other things i can do to help the mpg out??...K&N air filter?
Old Oct 18, 2004 | 09:37 PM
andym's Avatar
andym
Pull the codes - see if you have a sensor out of whack.
Old Oct 18, 2004 | 11:04 PM
oldntrd's Avatar
oldntrd
Thumbs up
Check your exhaust backpressure.
Old Oct 19, 2004 | 12:34 AM
ford_rulez17's Avatar
ford_rulez17
My 94' only gets 15 on a good day, and i dont think the k&n filter will make a diffrence
Old Oct 19, 2004 | 11:34 AM
Sn0wMan's Avatar
Sn0wMan
Ive been getting 10-11mpg in city...not cool. New fuel/oil/air filters, fresh oil. Ive replaced entire exhaust except manifold. Any advice?
Old Oct 19, 2004 | 03:38 PM
Tranzmaan's Avatar
Tranzmaan
gas milage
I have a 88 f150 4.9L with a 5 speed, around town I get 12-14 depending on how I drive. On the hiway it gets 19-20 mpg going about 75 mph or better. Someday I going to hold the hiway speed to about 60-65 to see what happens. I think its the constant shifting and hittin the gas to make her go that tears up the fuel in city driving.
Old Oct 19, 2004 | 04:21 PM
holland501's Avatar
holland501
Here is something you should consider. Moving a car or truck takes energy. We equate energy with gasoline and convert that to MPG as our standard for measuring. Two trucks, the same in every way except they have different engines. It can be 6 vs v8, small v8 vs big v8. It still takes the same amount of energy to move that truck. The difference comes in when the efficiency of the various power plants is factored. If you have an old, low tech, 6cyl vs a new, high tech big v8, you could actually get better MPG with the v8. It all comes back to the fact that takes the same amount of energy to move that truck no matter what engine is in it. The difference is going to be in how efficient is the engine, is there a significant weight difference, etc.
Old Oct 19, 2004 | 05:01 PM
faroffthetrack's Avatar
faroffthetrack
Mine's been getting as little as 8 mpg city, I've replaced or cheked everything i can think of.
Old Oct 19, 2004 | 08:14 PM
paulfix's Avatar
paulfix
I get 15.9mpg in city with a bit of highway. My buddy has a D*dge with a hemi and he tells me he only gets about 15, I expected him to get more and he says he drives sensible like
Old Oct 19, 2004 | 08:19 PM
'961506's Avatar
'961506
Fuel Filter! My bro just got one, got everything changed, including a bad thermostat, hid milege went from 'roun 11 to now almost 16.
Old Oct 19, 2004 | 08:31 PM
faroffthetrack
You name it, I replaced it.
Old Oct 19, 2004 | 08:59 PM
19903024x4's Avatar
19903024x4
Pulled the codes...113-Thermatic air system/ fault during engine run test.....my haynes book was no help.....any ideas?
Old Oct 21, 2004 | 01:38 PM
calazo's Avatar
calazo
Cool 8MPG tooo!
Well, I have a 1992 Bronco stock 1bbl carter 300cid 2WD, C-6, 3.08 gears and 29-inch tires, and I get 8MPG! My wife hates it! I only make $600/month (Colombia) and the gallon for 89 octane gas is $2.00! Prices will continue rising for a while (local government policy). I've been thinking about converting to natural gas, an increasingly popular alternative here, yet I've heard some bad things about it in this forum. Sad thing is that the I-6 is advertised as the "more economical" (14/17 MPG) of the three engines offered in late Broncos (302, 351W...) and certainly more economical (supposedly) than those M-Blocks, but after taking a survey here, the carbed I-6 coupled w/ the C-6 tranny is the most gas-guzzling engine, so ditch the six and get a V-8 or else...?! what to do?
Old Oct 21, 2004 | 02:10 PM
KAS300's Avatar
KAS300
All I've ever got with my truck is about 13 around town--1988, 5-speed, 3.55 rear end, stock size tires. Its not even that great on the highway. Sure, its capable of 20mpg if you drive 55 everywhere. But I drive anywhere from 65-75 when I go on a trip, and I usually get a touch over 15mpg.
Old Oct 21, 2004 | 05:25 PM
19903024x4's Avatar
19903024x4
i discovered that code has to do with emissions controls......gona dig into it this weekend and get it fixed...hopefully...i'd be happy if i could get it to 17.....driving to denver in november.....what it gets now will hurt bad if i gotta stop every 150 miles to fill up.
