cold idle problems
Old Oct 29, 2004 | 08:55 PM
silvapain's Avatar
silvapain
to clean the EGR valve, just take it off and douse it with carb cleaner. Just be sure to use a new gasket between the EGR valve and the UIM. It has a tendancy to leak if you reuse the old one. Also, be VERY careful when taking the nut off between the EGR valve and the EGR tube to the exhaust manifold. The EGR tube gets very brittle after a few years and will easily snap if too much force is applied to it. It's about $40 for a new one form the dealer - you can't get them from a junkyard because the junkyard guys will break them trying to get them off too.
Old Nov 8, 2004 | 09:47 PM
y2kranger's Avatar
y2kranger
Thanks everyone for all of the suggestions...
I have cleaned the MAF - didn't seem to make much of a difference. When the truck does "act up", it happens immediately upon start-up. Plugs and wires are next on my list of things to try... maybe the EGR as well.
I'll let you know what I find.
Old Nov 9, 2004 | 10:42 AM
vfrocket's Avatar
vfrocket
Mine was doing that... After, after a while it got worse, and even caused a CEL, misfire on cylinder 2.
I changed the plugs to Autolite AP764, and new plug wires... runs better than it ever has! purrs like a kitten, idles smooth as silk.
Biggwrm
Jan 12, 2012 10:22 PM
LI250
Oct 15, 2011 05:33 PM
johnsmith8369
1997 - 2003 F150
13
Feb 10, 2011 07:07 PM
yardbird
Modular V8 (4.6L, 5.4L)
Mar 31, 2005 08:08 PM
