Stiff Throttle
Old Dec 11, 2002 | 10:27 PM
bkarr2000's Avatar
bkarr2000
Stiff Throttle
I was wondering if there was anything I could do to loosen my throttle up. It is cold out now, and I don't know if the weather has anything to do with it, but I have to push a little harder on my throttle in order to get it to go. My throttle used to be free but it gets stiff now. It doesn't do it all the time, but off and on when I am driving. Like when I take off from a stop...it almost looks as if I am trying to race the guy next to me by the way my truck lurches, but it is actually because I have to use more force to get the throttle past the stiff point, and then it is like I am giving it too much pressure. Any suggestions? Thanks.
Bobby
Old Dec 11, 2002 | 11:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
Stiff Throttle
Check for a bind in the throttle body. You don't give any info about your truck so it is hard to say. Use some CRC Power lube on the linkage (not WD-40). Also a loose throttle blade can cause this problem.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Dec 12, 2002 | 05:50 AM
mathelm's Avatar
mathelm
Stiff Throttle
He's right, the gunk that builds up inside that throttle body is amazing. I used a whole bottle of carb cleaner and an old tooth brush ta clean mine. And lube the cables n springs on it, loosened mine up quite a bit. Mine wasn't sticking but it was a hard petal.
Why not WD-40?
Old Dec 12, 2002 | 11:14 AM
greenpus's Avatar
greenpus
Stiff Throttle
very common problem on the newer rangers. If cleaning the outside of the TB don't fix it then you have to replace the TB. I had to have mine replaced a couple of times on my 2000
Old Dec 12, 2002 | 12:07 PM
polar765's Avatar
polar765
Stiff Throttle
