General Automotive Discussion
dirtbike help
Old Oct 18, 2004 | 03:04 PM
BondoFord's Avatar
BondoFord
dirtbike help
does anyone know what would cause a dirt bike to run threw 4 gallons of gas in an hour and a half its a 1985 kdx200 if it helps usual 2 gallons last al after noon racin but the other day it suked dowun 4 galons on 1 n ahalf hours
Old Oct 18, 2004 | 03:11 PM
nick88f150's Avatar
nick88f150
U check for a leak somewhere? If it just happened suddenly, you coulda hit something or knocked a hose loose or something.
Old Oct 18, 2004 | 03:13 PM
BondoFord's Avatar
BondoFord
the only problem with that is it would of revd up suddenly n it didnt i put it on reserve n got half way homt then reserve ran out
Old Oct 18, 2004 | 04:09 PM
85e150's Avatar
85e150
Needle valve is leaking or stuck open?
Do you have fuel leaking out of the carb vents?
Is there lots of fuel in the exhaust?
Lots more smoke than normal?
Old Oct 18, 2004 | 04:14 PM
BondoFord's Avatar
BondoFord
no no morefurl in the exaust and it aint leekin from any wear
