transmission
Old Oct 18, 2004 | 08:26 AM
quizman1's Avatar
quizman1
Unhappy transmission
my transmission started staying stuck in second gear so I would let go of the gas pedal and step on it again it would shift did this for a month on my way home it totally stoped working got another tranny from a junk yard it does the same thing the truck rolls will not move did I get a bad tranny or is there something electronically that tells it to shift??? thanks victor.cruz@us.thales-bm.com
Old Oct 20, 2004 | 11:06 AM
quizman1's Avatar
quizman1
93 explorer
Does anyone know if there a seprate computer for transmission?
Old Oct 20, 2004 | 04:19 PM
mrshorty's Avatar
mrshorty
A '93 uses the same EEC-IV computer that controls the engine to control the 3-4 shift and the torque converter clutch (TCC) lockup. 1-2 and 2-3 shifts are controlled by engine vacuum via the vacuum modulator.
A bad vacuum modulator can cause it to get stuck in 2nd. The most common and telltale sign of a bad modulator is ATF being present in the vacuum line from the transmission to the engine.
