Lighted Running Boards Help
Thanks
Michael
I installed a light pack so whenever the key fob was tapped to unlock the doors the runningboard lights were tied in that circuit - wire,,
use a large flat blade scre driver and bently lift/pry up the plastic cover plate off the entry threshold or rocker panel cover below the door sill,, there are about 6 spring clips holding this sill plate on,, once it is lifter you will see a wire harness in the channel,, I seem to recall it was a green wire,,??? may want to take a volt meter and needle to probe the wires to see what is hot when the fob is used,, this wire eventually fed the bed light also,,
I removed the bed light but the color code of the wire you will see is not carried down to the rocker panel sill,,
once the correct wire is found I stripped it back for about 1/2 inch and tied my wire in and taped it good,, run the wire out one of the rubber plugs behind the door hinges and down under to the light pack,,
hope this helps,,
enjoy,,
