Gauge Correction
Something I noticed when I traded my '75 F-100 for my '79 F-250 was that the gauges were all off....well, I noticed right away that it appeared to be running really hot but actual temp readings we normal. I also noted that I drove from Olympia Washington to North Bend Washington and the fuel gauge went from F to E ( and it's only about a 40 minute trip...alarming if you you have a 300 mile drive and only $30.00 in your pocket ) but I drove on E all the way to Moses Lake ( another 2 1/2 hours ) Before checking the actual engine temps, I thought the temp gauge was fairly accurate and I had a stuck thermostat or something, and that the sending units were just failing in the tanks. After checking the engine temps and finding them normal, as well as the oil pressure ( which also read high ) it occurred to me that somebody had previously changed dash pods and that's why all the gauges except the speedometer and amp were out of whack. Is there an adjustment I can make to the gauges to bring them closer to accurate ? On a side note, I had a rebuilt alternator for my '75 that I never installed ( I-300 ) can I use it in my '79 F-250 ( V8-400 ) ?
Thanks !!
-Scott Jones
Spokane, Wa.
