new motor
Old Oct 17, 2004 | 09:27 PM
70highboy's Avatar
70highboy
new motor
Where is a good place to buy a new motor for my truck? I just want a stock short block.
Old Oct 17, 2004 | 10:35 PM
fordbeast_80's Avatar
fordbeast_80
What kind of motor do you have?
Old Oct 19, 2004 | 09:07 PM
70highboy's Avatar
70highboy
its a 360 but i was told to replace it with a 390. 4 speed. 4wd
Old Oct 19, 2004 | 09:54 PM
Goodold71's Avatar
Goodold71
Do you have a Kragens where you live? They sell longblocks for $1188.00.Just recently put one in a truck replaced a 360 with a 390.The total cost with core charge was 1609.00 but got 200 back when turned in core and that is with additional warrantee of 5 yrs 50,000 miles.I asked him today and he said it runs strong. Came with a melling HV oil pump also. Hope this helps.
Old Oct 20, 2004 | 06:08 AM
boomer202's Avatar
boomer202
Try WW.FORD-MOTORS-ENGINES.COM - probably the largest selection of ford motors (including FE)
Old Oct 21, 2004 | 07:56 PM
Goodold71's Avatar
Goodold71
well I found the problem....never use teflon tape on sending unit threads..it does not connect well therefore bad reading.
Old Oct 23, 2004 | 08:17 AM
qman's Avatar
qman
Couldn't you just get it rebuilt locally for about half that? I noticed in a spec sheet that the 360 and 390 have the same bore. The blocks also look alike. I'm guessing that the only thing different is the stroke. Maybe longer rods and/or different crank. I thought you could get these things rebuilt for $500-600.
Old Oct 23, 2004 | 09:48 AM
Chris Nikirk's Avatar
Chris Nikirk
Here in Houston Thunderbolt sells a 390 long block for $850 and a short block for somewhere south of $600.
