My 2001 Ford SD door ajar light will not always turn off. Which means at night the dome light stays on forever. Sometimes I can make it go off by hitting the auto door lock off and on several times, but that doesn't always work. Any suggestions? Thanks
Hey Walkerrim.
Does your door lock on the door have any greese on it? If so, you might need to clean it with a spray degreasser real goooood, then use a light spray lube on the lock mech. Its the part on the door itself, black plastic. The grease on the switch might be causing a problem for you. Good luck.
