How do you remove the rear and side paneling in a 98 lariat, three door. Trying to get out the 6 CD changer with no luck at all. I don't want to but I am considering using a screwdriver to pry it out!!!!!!!!
you need to buy the ford stereo removal tool from autopart stores, circuit city, or best buys. The tools look like two mini u-bolts.
As far as removing the side panel, you might want to remove the back seats then remove the bolt holding the seatbelt anchor on the c-pillar. Remove the weather strips. Pull on the panel. The panel is held by friction clips and seatblet anchor bolt.
