bronco won't start
Old Oct 17, 2004 | 09:53 AM
th0mpson182's Avatar
th0mpson182
bronco won't start
for some reason my truck just starts maybe one in two times now. Like ill turn the key and get a click, then turn it back and try again and it slowly slowly slowly starts up... ive recently replaced battery (yellow top optima), alternator (200 amp), and solenoid!
Old Oct 17, 2004 | 10:17 AM
Dealford's Avatar
Dealford
And that leaves the starter & cables.
Is there any obvious problems, corrosion, worn out insulator, with the cables?
Pull the starter off & have it checked.
AL.
Old Oct 17, 2004 | 02:58 PM
th0mpson182
yea like when i turn the key the battery has plenty of power etc... i relaly think its the starter
Old Oct 17, 2004 | 03:42 PM
Monty06's Avatar
Monty06
could be your starter relay
Old Oct 17, 2004 | 08:32 PM
Dealford's Avatar
Dealford
All the heat created by the old starter could "cook" the relay. Best to change it as well with a good one from Ford while you're at it.
AL.
Old Oct 18, 2004 | 02:13 PM
th0mpson182
replaced the starter and she cranked up quicker than when I got her! thanks guys
