1978 - 1996 Big Bronco
1990 headlight beam adjustable?
Old Oct 16, 2004 | 10:32 PM
JBronco's Avatar
JBronco
It looks like the headlight on a 1990 is fixed. Can the beam hight be adjusted on a 1990? Thanks
Old Oct 16, 2004 | 10:58 PM
greystreak92's Avatar
greystreak92
If they are like the later models there is a tiny hex-head rod sticking out from behind the bezel under the hood in front of the upper radiator crossmember. This will change the "pan" (left-right) adjustment. The "tilt" (up-down) is a Philips head screw behind the upper inboard corner of each headlamp. This may not be true for the 91 and earlier models but all headlamp assemblies are adjustable. They have to be in order to comply with variances in state laws regarding viewable night distances.
