Please help identify this engine
Old Oct 16, 2004 | 07:52 PM
Loganwildman's Avatar
Loganwildman
If I read it right from the mirror, the block code is E4AE-6012-FA11
Thanks
Old Oct 16, 2004 | 08:02 PM
guzzler96's Avatar
guzzler96
Question
Where did you find this number?? Chilton's says the engine ID tag is located under the ignition coil attaching bolt on most engines except the 6.9L and 7.3L diesels. Engine ID format seems to be different from what you found.
Old Oct 16, 2004 | 08:13 PM
Chris_ce's Avatar
Chris_ce
Are you needing to know if it is a 302 or 351w? A 351w messure across the intake it should be 11 inchs a 302 is 9 inchs. The numbers you posted says it an engine that was cast in 1984.
Old Oct 16, 2004 | 08:17 PM
Loganwildman
It was on the block above the starter. I am trying to determine if it is a 302 or a 351W
Old Oct 17, 2004 | 08:31 PM
Frankenstang57's Avatar
Frankenstang57
Easiest way to tell a 351W from a 302 is this; look at where the head meats the block. If it's a 302 there will be little distance between the head and where the timing cover is. If there is about an 1", its a 351W.
