Sponsored by: Kumho
brake hose removal
Old Oct 16, 2004 | 12:33 PM
someday's Avatar
someday
brake hose removal
i have a 95 v6 mustang and when i put dual exhaust on, the rear center brake hose that is attached to the differential is burned and leaking. How does the brake hose connected to the differential come off?
Old Oct 17, 2004 | 04:10 AM
angus's Avatar
angus
Does it screw into a brass T fitting that is bolted to the diff? That's how it is on my trucks. If you clean it off it should be easier to tell what's going on.
Old Oct 17, 2004 | 04:11 AM
angus's Avatar
angus
Old Oct 18, 2004 | 05:51 PM
someday's Avatar
someday
i actually started before your post, but when i started messing around with what looked like a vent cap. after a few minutes i knew that it was not holding it on and with the right light and some cleaning i noticed it was bolted on and it came right off. anyhow thanks for your help
