General Automotive Discussion
Jacking up rear on diff. housing
Old Oct 15, 2004 | 08:08 PM
mwh's Avatar
mwh
Exclamation Jacking up rear on diff. housing
I have been having brake work done (for years) at a shop that uses a contact jack on the differential housing.They don't have lift racks. Even on a '81 full size Dodge van that I own. They apparently seem to think it's OK and have always done this. Is this OK on the older vehicles. I need feedback from those who really know-thanks
Old Oct 15, 2004 | 08:15 PM
theologian's Avatar
theologian
It is possible to damage the housing, by lifting the end of the vehicle up by it. I have seen a cracked diff housing on a 1 ton, that was lifted by such a means - I never allow anyone to use a jack on mine, I make very sure of that, standing close by, and glowering.
Old Oct 15, 2004 | 08:16 PM
crazandy's Avatar
crazandy
I do it all the time, but be carefull. With some vehicles (chevy extreme's for example) they tend to want to slide off of the jack.
Old Oct 15, 2004 | 09:46 PM
rebocardo's Avatar
rebocardo
It is more okay on older vehicles then newer ones because older vehicles have heavier rear axle housings, in general. On newer vehicles I would not try it, you can destroy a newer Camaro just by giving it a regular front end tow, I do not think I would try lifting it several feet off the ground by the rear axle.
I do not know what you mean by a contact jack or what it is. I have seen rear end lifts that lift by the rear pumpkin and the brackets that you stand up near the end of the axle tubes so it lifts in three places.
Do they lift it entirely by the pumpkin and then lower it onto jackstands?
I know when you lift a light duty truck by the pumpkin you can actually see the ends of the axle deflect downwards. It is not something I would go out of my way to do.
Old Oct 15, 2004 | 10:01 PM
mwh's Avatar
mwh
Rebocardo-yes they lift it by the pumpkin and then lower it on jackstands. This shop has a very good reputation..I've seen quite a few customs and specialty vehicles come in this shop, however once a musclehead mechanic got carried away on the front-end of my '77 Nova with the same type jack and it slipped off the front-crossmember and damaged the oil pan to where the owner bought that one.
Old Oct 15, 2004 | 10:27 PM
66 Ranger's Avatar
66 Ranger
I jacked up my 91 Explorer rear end in the middle with a floor jack. The next morning all the rear axle lube was on the shop floor. Cracked the cover, it is plastic!!!!!!! It's got a nice chrome one now.
Old Oct 15, 2004 | 10:47 PM
Ultramagdan's Avatar
Ultramagdan
The owners manual says not to jack up the vehicle by using the rear diff. I have done it but only with no load. I can see where it would not take much to crack the housing.
Old Oct 15, 2004 | 10:55 PM
DonsFx4's Avatar
DonsFx4
There's a band named for people who do this:
SMASHING PUMPKINS
Old Oct 16, 2004 | 04:52 PM
rebocardo's Avatar
rebocardo
Yea, the axle can deflect enough to crack a plastic cover. Then again, the plastic cover on a Explorer is a one use cover and you are better off with a metal one anyways, imo.
Old Oct 16, 2004 | 04:55 PM
peppy's Avatar
peppy
A plastic diff cover. How embarassing.
Another bad idea Ford let slip by into production.
Old Oct 17, 2004 | 02:55 AM
Mike W's Avatar
Mike W
Save $.50 here and there and it adds up to real money. I have lifted cars and trucks with a 9" rear end by the housing for upteen years and never had a problem.
Old Oct 17, 2004 | 11:20 AM
crazandy's Avatar
crazandy
The vehicles I've lifted by the diff and havn't had any problems are:
- 79 CJ5 with waggy AMC 20 rear
- 84 Ford Ranger with stock rear
- 02 Chevy Extreme with stock rear
- 68 J3000 with D53 rear
- 92 Jeep Cherokee with stock front and rear
Old Oct 17, 2004 | 03:45 PM
JerseysBest's Avatar
JerseysBest
thats how i jack up my 68 mustang with a 9in, how else are you gonna do it
Old Oct 17, 2004 | 04:02 PM
kotzy's Avatar
kotzy
Even with the steel covers there was a chance that you could catch the cover
with the jack pad retainer lugs and bend it resulting in a leak. As far as cracking the
cast steel housing I sure hope not or I wouldn't want to put the torque of an engine
against it. I have rebuilt Dana's Rockwell's and some others I only saw one housing
fail that was a Rockwell that broke the differential cross.I think jacking them with the housing requires one thing care and common sense.
