96 Cruise Help
Old Oct 15, 2004 | 05:39 PM
Fair 96's Avatar
Fair 96
96 Cruise Help
I got a 96 F 150 supercab and the cruise control just quit working. I mean it does nothing like it is dead. I checked the fuses in the fuse panel under the dash and not sure wich fuse it is I checked all of them, They all are fine. Any Ideas of what is wrong or is there a fuse or fusable link somewhere else. Any help appreciated...
Old Oct 15, 2004 | 07:58 PM
zieg96's Avatar
zieg96
Without going to my owners manual there is more fuses under the hood. It may be out there. Thats where I found the one for the trailer running lights that I had blown.
Old Oct 15, 2004 | 08:05 PM
DCN's Avatar
DCN
Check to see if any tail lights are out. I got a 96 too and when my right rear tail light went out (directional) my cruise control would shut off when I put my turn signal on.
Old Oct 15, 2004 | 09:00 PM
merckx72's Avatar
merckx72
Okay.
If It Is Not The Fuse Then It Is The Connection Under The Hood.
Pop The Hood. Follow The Cable From The Throttle Body To The Cruise Control Throttle Control. Check The Wire Connections. They Are Famous For Getting Dirty From Splashed Water And Dirt Clean And Seal. MY 96 quit for a while until i stumbled onto the repair.
Old Oct 18, 2004 | 08:58 AM
Fair 96's Avatar
Fair 96
Thanks everyone I will try your tips today and let you know...
Old Oct 18, 2004 | 10:37 AM
Fair 96's Avatar
Fair 96
Ok all fuses are good. I pulled off the wire harness to the speed control servo to check for corrosion. I found a liquid stuff I first thought was water but feels more like a very light oil. Is this supposed to be wet ?? Possibly an anti corrosion stuff put there from factory?? Anyway there is alot of it coating all connections. What is the best way to clean the connections ??
Old Oct 18, 2004 | 12:43 PM
Lumpy87's Avatar
Lumpy87
I read somewhere here that brake fluid from the master cylinders can leak down from the connection there. Usually the stuff to prevent corrosion and aid conduction is a special white or grey grease.
Old Oct 18, 2004 | 03:03 PM
merckx72's Avatar
merckx72
clean it with some paper towel or blow it out. after you reconnnect you can coat the outside with silicone cauls to keep crap out. does the cruise control work now?
Old Oct 18, 2004 | 05:25 PM
Fair 96's Avatar
Fair 96
The cruise doesnt work yet I will try cleaning the connection. It does kinda look like brake fluid now that you mention it...
Old Oct 26, 2004 | 01:38 PM
Fair 96's Avatar
Fair 96
I found the problem after doing the million point check in my newly bought Ford service manuals ( these are great books and I highly recomend them) I believe it to be the Deactivator switch that is located on the master cylender.....
Thanks everyone for the help
Old Oct 26, 2004 | 08:04 PM
my93's Avatar
my93
On my 93 I had the same problem. The 93 does not have air bags as a word of caution of which yours probably does. I learn the following from a senior member here when I posted my cruise control did not work. This was his first answer.Under the steering/wheel column there is a small panel cover you remove to get to the crusie control cable. The cable connection over a period of time may be jarred enough to break the cruise control connection. To look at it, the plugs appeared connected good. I wiggled and push the female/male plug's together and Wha la, the cruise control began working again.That was 2 years ago and it is still working thanks to the informative answer I recieved from this forum.
Old Oct 27, 2004 | 01:41 PM
Fair 96's Avatar
Fair 96
I replaced the deactivator switch and all works now..
Pkupman82
54
Feb 4, 2018 01:51 PM
kupiec20
34
May 3, 2013 07:59 PM
cpulliam
Feb 29, 2004 01:05 AM
rodneybroadway
1997 - 2003 F150
Oct 29, 2002 12:07 PM
