Dull knocking
Old Oct 15, 2004 | 03:16 PM
blwilli's Avatar
blwilli
Question Dull knocking
ok, quick question y'all. What would make a dull, solid knocking (like a hammer hitting a steal beam) that is louder at the bottom of an engine?
Old Oct 17, 2004 | 01:43 AM
hate2loveford's Avatar
hate2loveford
Assuming that the engine isn't actually thinking of throwing a rod out the side of the block..., check the catalytic converter cover. Mine had a weld or two break and it made a horrible rattling sound at certain RPM ranges until it was rewelded.
Old Oct 17, 2004 | 09:19 AM
blwilli's Avatar
blwilli
nope, not the cat in this case...its NOTHING like a rattle...nice consistant Knock.
Old Oct 17, 2004 | 08:48 PM
rusty70f100's Avatar
rusty70f100
What engine is it and does it do it all the time? Piston slap sometimes makes a knock.
Does it occur at full engine speed or half engine speed?
Old Oct 26, 2004 | 08:41 AM
blwilli's Avatar
blwilli
it has the 4.0L (1993 Explorer)...does it ALL the time, worse under load.
Old Oct 27, 2004 | 10:19 AM
mrshorty's Avatar
mrshorty
Worse under load? Is it spark knock (aka ping)? Fairly common to these engines.
Old Oct 27, 2004 | 11:28 AM
blwilli's Avatar
blwilli
no, it is not a spark knock...no, there are no fault codes, yes, it is worse under load. Not to mention, it is louder at the BOTTOM of the engine, whereas spark knock would be in the heads. No, it is also not a rattling catalytic converter cover (actually, that cover isn't even there anymore).
Quadsport
May 16, 2013 08:17 PM
73f350sc
S. California Chapter
Nov 11, 2007 08:57 PM
fixnair
Garage & Workshop
Jul 31, 2007 03:57 PM
ktown1965
1997 - 2003 F150
Jun 20, 2005 05:15 PM
edub32
Jun 12, 2005 05:56 PM
