Is there a 12V block heater?
I won't have access to 120V and need to park in very cold weather.
Has anyone tried using an inverter hooked up to a battery jumper pack?
Never heardof one. Your block would be warm and your batteries would be dead!! How long will you be doing this for. A small generator locked in the back of your truck would probaly work. Just fire it up acouple hour before ya go and you should be good. Good luck!
I will be working a 12 hour shift so the truck would sit for that long in 30 degree and less weather.
Then I would fire it up and drive to a hotel when it would sit for the rest of the night or about 11 hours.
Can you get a hotelroom on the ground floor. Maybe you could sneek a cord out the window or something. As for through the day go out and start it every 3-4 hrs if you can. This will help keep some heat in it.
I used to live in Montana, try this, Warm it up just before you go to sleep, let it cool a little bit, then put a blanket over the engine or like a canvas tarp and space blanket. It will suprise you how much heat this will hold in.
Just remember not to put it on anything too hot and dont forget to take it off.
I have also seen people use bbq briquettes under the engine. THis one scares me though becuase there could be oil or fuel under the engine that could start on fire.
Oh, and if you're really concerned about having a block heater which doesn't need power, Webasto used to make a whole array of propane fueled block heaters. I haven't been to their web site lately though.
I don't recall saying that it wasn't working correctly. Of course, you may be psychic and know something I don't.
Sorry didn't mean to offend. I went back and read your first post and no you didn't say anything about hard starting. I just assumed since most people have hard starting if they are asking about a block heater. I was wise cracking at the charcoal briquettes idea.
Personally I don't know of any 12v block heaters. As a previous post said it would drain batteries real quick.
I plug mine in just because it seems to be easier on things when it gets colder, it will start when it is wayyy cold, but it doesn't seem to labor as bad when plugged in. Go to wal-mart or a camping supply store and get a thermal blanket like doc-nomad said. I had a truck go down in Montana during the winter and I covered the motor up while working on it, and it trapped enough heat in to be able to get it lit.
Kwikkordead is psychic. It was 31 last night when I tried to start it. It wouldn't start. Luckily, I was parked near a 110 outlet and was able to plug in for 1/2 an hour to get it to start.
Right now, I have an extension cord running out my hotel window to the truck.
