Help with '98 Codes
Old Dec 31, 2002 | 09:54 AM
f_pumillo's Avatar
f_pumillo
Help with '98 Codes
I have a 98 Ranger 3.0 V6, uisng my SCMT in diagnostic code I get the following codes P0401, P0402 and my check engine light is on. The book that came with the SCMT states P0401 = "Exhaust Gas Recirculation Flow Insuff Detected" and P0402 = "Exhaust Gas recirculation Excessive detected" Either the engine can't make up its mind or a sensor is going. I would appreciate any help, 1) If these codes are correct and 2) what might be the trouble? :-X12
I use the SCMT to tune my 01 PSD X.
Old Dec 31, 2002 | 10:17 AM
Racerguy's Avatar
Racerguy
Help with '98 Codes
Most likely needs a new DPFE sensor.
Old Dec 31, 2002 | 11:38 AM
fordlvr25's Avatar
fordlvr25
Help with '98 Codes
yup change the dpfe sensor, i had the same problem with my 99 and same code p0401 changed the sensor, erased the code and it hasnt come on since. hope this helps
Old Dec 31, 2002 | 12:35 PM
f_pumillo's Avatar
f_pumillo
Help with '98 Codes
I'll give that a try. Thanks much and Happy New Year.
Old Jan 1, 2003 | 08:41 PM
Rand's Avatar
Rand
Help with '98 Codes
