1978 - 1996 Big Bronco
Manual locking hubs
Old Oct 15, 2004 | 06:24 AM
HMA-169's Avatar
HMA-169
Arrow Manual locking hubs
Just bought some new Warn premium locking hubs and conversion kit for my '96 Bronco. Is a special tool required for the spindle nuts? Can a spanner wrench be used, or does it require some kind of socket?
Old Oct 15, 2004 | 08:36 AM
BigfootWannabe's Avatar
BigfootWannabe
It requires a socket. I got one at the local Autozone. But they gave me the wrong one at first, had to go back and exchange it.
Nevertheless it is available and a good tool to have, especially if you ever go in the water, as you will have to get to those bearings to relube after mud runs and water runs.
BFW
Old Oct 15, 2004 | 08:58 AM
HMA-169's Avatar
HMA-169
Arrow
Thanks for the info.
Do you know anything about the Detroit E-Z locker differential? It sounds interesting in that I could probably install it myself. However I want some that works well if I am going to the trouble of putting it in. In that regard, I'm considering the Auburn limited-slip differential but would probably have to have it installed by a professional.
Old Oct 15, 2004 | 08:09 PM
Bronco3's Avatar
Bronco3
I put in Warn hubs on my '95 about a year ago. Conversion was easy took about an hour to do both sides. I have been extreamly happy with them since.
Good luck!
Old Oct 15, 2004 | 10:02 PM
BigfootWannabe
Yeah, I got the warn premiums on my '79. I am very happy with them. Although I do not believe you have to go as deep as the spindle nut to put them in.
I did the bearings and races while I had the wheel off, thats why I had to go get a spindle nut socket, if your just doing the hub locks I don't think you need it.
Sorry, don't know anything about the Detroit EZ locker.
BFW
