1978 - 1996 Big Bronco
Hollowing out Cats?
Old Oct 15, 2004 | 12:28 AM
cactusbronco's Avatar
cactusbronco
Hollowing out Cats?
Guys, I read in one of your posts that you hollowed out the top converter and replaced the bottom one. Will my rig pass emissions if I do this?
Old Oct 15, 2004 | 09:27 AM
Kemicalburns's Avatar
Kemicalburns
depends on how the motor itself is running. if it has low miles, doesnt burn oil or blow smoke you should be ok. but if your going to replace the bottom one why not just get a hi flow cat to replace both. it is legal you know.
Old Oct 15, 2004 | 12:27 PM
bronco_94's Avatar
bronco_94
where would ya find a high flow cat, for a cheap price?
Old Oct 15, 2004 | 12:28 PM
ojosdestranger's Avatar
ojosdestranger
If you are worried about emmissions and don't want to spend money with CATs, I'd recommend getting SEA FOAM to clean out the insides of your engine. Follow directions printed on can. It will be the best $5.00 you will spend...
-Stranger
Old Oct 16, 2004 | 05:24 PM
greystreak92's Avatar
greystreak92
Just replace the stock Y-pipe with the Bassani unit that has the high-flow CAT in it already. Gets you everything back to the muffler new, stainless, and will bolt right up to the stock manifolds without modifications. Of course there is the dilema of having 3" diameter exhaust back that far and a stock muffler....hmmmm. OK, well it was a nice idea while it lasted.
Just keep in mind that even if you don't have inspections in your area, the deliberate removal of emissions equipment isn't a great idea.
Old Oct 16, 2004 | 09:49 PM
cactusbronco
Inspections
Oh yeah, we have emission inspections and it is a royal pain if you fail them. I was just trying to get out of replacing both cats. It's tight out here since our air quality is getting bad ie. Phoenix is becoming "Little LA".
