2001 Excursion and Prodigy Controller 911
Old Oct 14, 2004 | 10:27 PM
damone's Avatar
damone
I got a 2001 Excursion Diesel 4x4 w/ tow package.
I have a prodigy controller and the factory Ford harness was cut leaving just 5 wires. Blue, Black, Red, White and Whitew/ Blue Stripe.
I connected all except white w/blue stripe.
Checked all fuses & relays and they are good.
No power to prodigy.
Looked in engine compartment and saw same 4 wires I hooked up in cab. They were all cut also. They were next to fuse box and running down towards box. I exposed wiring harness to see if the other end was there somewhere & they were not. So I took Prodigy out of cab and hardwired directly in engine compartment to same four wire running to fuse box. Nothing.
What do I do know? Got truck yesterday and of course sceduled to leave at 8am. I'm screwed. Any help?
Thanks,
D
Old Oct 15, 2004 | 08:56 AM
SilentlySoaring's Avatar
SilentlySoaring
Well, it's unfortunate that someone cut the connector under the dash. Otherwise it would have been simply a "plug & play" situation. Since I didn't have to resolve your issues, I can only suggest that you contact Tekonsha directly, or a local trailer/hitch shop. Either should be able to advise you over the phone. The question is, how much off schedule will you be (regarding your intended 8 AM departure).
