Sponsored by: Auxito
Rear Window
Old Oct 14, 2004 | 09:12 PM
dumpsterdan's Avatar
dumpsterdan
Question Rear Window
Anyone know where I can detailed step by step instructions to remove the one piece rear window on my '97 and install a slider window? Is there any problem if I try to use an original from the salvage yard?
Old Oct 14, 2004 | 11:03 PM
homer4.2's Avatar
homer4.2
yea, its called a baseball bat man
Old Oct 15, 2004 | 08:35 AM
dumpsterdan
Well, that gets the old one out. How about installing the new?
Old Oct 16, 2004 | 10:17 PM
Rocky J's Avatar
Rocky J
And what is with the funky plastic window frame? I just bought a 2002 and have noticed that the rear window frame is all kerfluieey. The seal is out of place and there are a couple 1/2" gaps between the frame and window on a couple corners. Luckily I have a 100 day warranty so I'll just make the dealer fix it, but will this be an ongoing issue and is it an easy fix?
Old Oct 16, 2004 | 10:35 PM
Ultramagdan's Avatar
Ultramagdan
It's not hard. Strip the interior and remove the bolts that hold the window on. Takes about 2 hour from start to finish. I would NOT use an orginal from the salvage yard as the frame is most likely cracked at the pillar and will leak. If you are going to install a slider, buy a new one.
