Tire Size
Old Oct 14, 2004 | 08:15 PM
BuddyFord's Avatar
BuddyFord
Tire Size
I have a 1994 F-150 4x4 Longbox, 300-6. 5spd with 3.55:1 axle ratios
Stock height, My question is, what is the largest tire I can fit without a lift, or Bent arms, or new offset rims? I have stock rims and want to keep them. I am looking at a set of 31x10.50 Thornbirds, and I want to make sure i am not going to end up with rub on the Radius Arm. what would you all reccomend for tire size? I am looking for a tire to "fill the hole" a litle better, as i feel I have too much frame showing around the tires. I also wouldn't mind a little better fuel economy, as the engine is at 2000 RPM at 100Km/h ( about 60 MpH if I figured it out right) I am considering a taller 5th gear, but that's in the future, a I JUST had the transmission rebuilt, and forgot to ask about it. so, Largest tire size on the truck, fitment wise. once I fing the tire size, I can ask around and see if i have a friend with the same size so I can test driveability
thanks,
Dave
Old Oct 14, 2004 | 08:18 PM
jamesdart's Avatar
jamesdart
i had 31x11.50's on my 86.
Old Oct 14, 2004 | 08:28 PM
omni's Avatar
omni
I ran 31x10.5 on my 91 4x4 and sometimes got a little rub on the radius arms, but only with the tightest of turns, I think you could run a 32x11.5 if you just remember not to crank it to tight on sharp turns
Old Oct 14, 2004 | 08:29 PM
jamesdart's Avatar
jamesdart
i actually dont remember if mine rubbed the radius arms or not. sorry.
Old Oct 14, 2004 | 08:37 PM
christaylor's Avatar
christaylor
my 95 150 4x4 has 31x10.5 Cooper sst's and they have NEVER rubbed. It looks like I could go a bit bigger but the lift is coming next and I will want bigger tires then. The 3.55's will handle the 31's but you will lose some "take off" power. You will probably want new gears next.
Chris
Old Sep 7, 2008 | 12:45 AM
Glockm22's Avatar
Glockm22
I have 31x10.50 MT Baja claws on my 89 4x4. No problems at all in any terrain with clearance issues.
Old Sep 7, 2008 | 01:23 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
I think i would be more worried about the power to turn the bigger tire. I will say that 33"s rub very minimally. So 31's you should be fine... Just consider the power to turn those tires.
