Noisey Steering
Old Jan 6, 2003 | 10:33 AM
B in TX's Avatar
B in TX
Post Noisey Steering
Hoping someone can help out. My '97 F150 has very noisey steering (people turn their heads in the parking lot). Power steering fluid is fine, joint is greased, it's not hard to turn, just NOISEY!! I've since heard another F150 and and Explorer making the same noise when turning. Any suggestions??
THANKS!
B
Old Jan 6, 2003 | 08:35 PM
rebocardo's Avatar
rebocardo
Noisey Steering
I can usually tell a Ford without seeing it by the noise the pump makes. It is normal. The good news is, unless you go off-roading a lot with big tires, that the pump generally will outlast everything on the truck except maybe the steering box.
Old Jan 6, 2003 | 10:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Noisey Steering
Hello-
Welcome to Ford Truck Enthusiasts! The Internet's leading Ford TRUCK and SUV Resource!
The sound is not normal. It is a sign that your pump is worn out thru abuse or neglect and it is bypassing fluid from the high pressure side back to the inlet thru grooves worn in the valve plate. Replace the pump AND put an inline filter on it.
Thanks for using FTE!
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID75&conf=genconf |Garage and Shop] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID116&conf=DCConf ID9|Ranger] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID91&conf=DCConfI D12|1973-1979 Ford trucks] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID93&conf=DCConfI D8|1997-2003 F150 and E150 Forum]
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Jan 7, 2003 | 01:26 AM
RBrendel's Avatar
RBrendel
Noisey Steering
