Bronco II Ford Bronco II
Need advice about heads
Old Oct 14, 2004 | 05:32 PM
threespeed's Avatar
threespeed
Question Need advice about heads
I have disassembled the top end of my 2.9L in my son's 89 B2 and I am down to the heads and exhaust manifolds. I would like to know if I can remove the heads with the exhaust manifolds still bolted to the heads?
Old Oct 14, 2004 | 07:15 PM
tchile's Avatar
tchile
removal of heads with ex manifold
yes, yes you can. also it is the only way to reassemble. on reassembly try to put some slack in the exhaust pipes so the head will fit flat when you set it down. that trick about making head guide bolts is a very important step in the process.
Old Oct 14, 2004 | 07:52 PM
threespeed's Avatar
threespeed
thanks tchile, that helps alot!!
KraZeDav
Exhaust Systems
Jun 29, 2016 07:46 AM
clhart426
Oct 29, 2009 08:13 AM
Redneck1465
19
Jul 30, 2008 12:37 PM
Chilako
Sep 16, 2006 07:12 PM
dburgess
Apr 24, 2004 09:10 AM
