2005 Trailer brake controller
Old Jan 13, 2005 | 09:36 PM
charon61285's Avatar
charon61285
some how I double up on this one. see next post by charon61285
Old Jan 13, 2005 | 09:38 PM
charon61285
All you do to install the unit is put a Tee the brake line with a pressure sensor on one side to the tee and of course the brake lines on the other two sides. Bleed out the air and check the fluid level the the brake fluid resevour.
Next run the wires from the sensor to the master unit and plug in thw wire from the master unit to the trail brake harness, Mount the master unit. Put in any info about your trailer etc. and hitch up.
I have not made any adjustments to mine at ALL, but will review all info before I hookup again next spring.
Yes some fancy dan of a Lawyer or service rep may say that you have "modified" your brake system, BUT what you do what to do, stop your rig quickly and smoothly or worry about something that rarely fails, ie master cylinder or the like.
I choose the stopping part!
I have had TOO MANY people in cars (4 wheelers) pull a "fast move" in front of me causing me the jump on the brakes and HOPE I could stop. This controller has lowered my level of concern about stopping fast and smoothly.
Not all the "Blue Smoke" coming from my truck is from the exhuast, some of it goes out the drivers side window.
Besides if I can't stop and hit someone from the rear, I have bigger problems that worrying about will Ford void my warranty if I use an after market item.
I can now get off my soap box!
Thanks for listening.
Old Jan 13, 2005 | 10:06 PM
Steina's Avatar
Steina
CO River Rat
charon61285 -
I agree with what you said; I used the word "possible" as a heads-up due to the fact that Ford is looking at warranty repair costs really hard. I use a Prodigy controller that plugs directly into the under-dash connector; if it caused an electrical malfunction I'd probably be SOL warranty-wise.
Steve
brianrowe
Sep 18, 2014 08:30 AM
blackgold50
All Things Towing
Jul 31, 2014 05:11 AM
KHAYES
All Things Towing
Jun 12, 2013 12:09 PM
Bsousa
Sep 17, 2011 06:08 PM
Brian0445
Oct 20, 2008 04:46 PM
