1978 - 1996 Big Bronco
Banging in front end
Old Oct 14, 2004 | 01:38 PM
wayne100's Avatar
wayne100
Hit a bump on the way home last night and heard a bang. Went out this morning and now every little bump I hit I hear a banging noise, like something is moving and hitting. I jacked it up and everything seems tight. I tried moving the wheel up and down and left and right but no movement. I tried jumping up and down on the bumper shocks seem ok but I did hear a squeeking noise. I had my radius arm bushings replaced about 6 months ago. Any ideas?
Old Oct 14, 2004 | 01:46 PM
snowmobilerfreak's Avatar
snowmobilerfreak
Motor mount? I dunno....your not giving us much to go on...so you hear a bump that could be anything in the front. Maybe you can be more specific.
Old Dec 31, 2004 | 03:22 AM
scaryharry's Avatar
scaryharry
Check the bushings on your shocks. It could be metal on metal making the noise at each bump.
Old Dec 31, 2004 | 09:34 AM
FixItNow's Avatar
FixItNow
Check sway bar bushings also, if they wear out and fall out the sway bar will hit the frame.
Old Jan 1, 2005 | 09:08 AM
broncr's Avatar
broncr
Radius arm & center pivot bushing wear can also cause a loud "banging" sound...
'hope it's something else!
Old Jan 2, 2005 | 04:21 PM
phoneman71's Avatar
phoneman71
Check and make sure that the rubber bump stop on the frame directly above the axle isnt missing nor damaged.
This rubber bump stop prevents the axle from compressing into the frame when going over a bump. If this bump stop is missing--there will be a bang heard when the axle housing hits the frame member. I have had this happen on other trucks--very noticeable!!!
