I've had trouble with the ABS light. It comes on periodically as well as the speedometer fading in and out. And now it comes on every time you go somewhere.
I've recently replaced the sensor on the top of the rear differential and that didn't solve the problem.
Over the past year I've also noticed the Expedition wants to pull to the right under acceleration.
Are the two related?
What else could be causing me trouble?
Any help would be great.
Dumb Question but have you had your brakes checked?? From what you describe, It sounds like you might have a brake issue. Also would not hurt to check your alignment & Balancing on your tires....
Yeah....It started before the last time I changed the brakes. It seems to be some type of "slip" in the front axle. Since it is an AWD I wasn't sure if there was some type of front wheel sensor that was shifting the drive of the wheels from side to side causing this pull. I wasn't sure if there was some type of ABS sensor in the front axle?
