4.0 code 171/174
Old Jan 7, 2003 | 02:40 PM
ka1cu's Avatar
ka1cu
4.0 code 171/174
Hi guys:I have been getting the 171/174 codes,I have replaced the 3 oxygen sensors,MAF sensor,Checked for vacuum leaks on hoses and the throttle body with ether.I'm out of ideas truck has 75k on it.any suggestions would be appreciated.thanks Mike
Old Jan 7, 2003 | 03:44 PM
Ken00's Avatar
Ken00
4.0 code 171/174
I have heard about vacuum leaks on the intake manifold/fuel rail area on 4.0s, also check for exhaust leaks and wiring problems.
Old Jan 9, 2003 | 07:58 PM
David S's Avatar
David S
4.0 code 171/174
According to success stories on the forum, MAF or PVC valve(and/or hoses) if it's not o2 sensors.
Old Jan 10, 2003 | 04:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
4.0 code 171/174
Old Jun 26, 2005 | 07:08 PM
kennyiii_65's Avatar
kennyiii_65
My 97 4.0 Ranger had this problem (for a few years). I finally decided to change the plugs & wires. EGR was in two pieces (rust) so I decided to take it to a shop. I has around 100k miles. After this work was done, it still ran rough. The Mech, said the upper intake manifold gasket was leaking. He was able to verify it by spraying around the suspected area. The spray sucked into the gasket area and the engine ran fine for a few seconds.
I had the gasket replaced and the truck runs like new.
Kenny III
