Fast Idle
Old Jan 8, 2003 | 09:06 PM
Cbike9's Avatar
Cbike9
Post Fast Idle
I have a 94 with a 4.0. when i bought it the idle was high like around 1600 rpm's +or- a couple hundred it changed often. I replaced all the sensor's in the intake portion and fixed a couple of vacuum leaks. now with no leaks and an extra return spring it won't idle any lower than a 1000 rpm's and this is with the idle adjust screw all the way out.
I apreciate any help. it has a 5 speed in it so the high idle isn't good for the constant necessity to shift.
when i let off the pedal the idle drops to about 1200 or 1300 and then tkes a couple seconds to drop to a grand, i think that part is normal but just in case.
Old Jan 9, 2003 | 08:45 AM
Ken00's Avatar
Ken00
Fast Idle
Are you 100% sure you don't have a vacuum leak, what happens if you disconnect the IAC?
Old Jan 10, 2003 | 01:02 PM
Cbike9's Avatar
Cbike9
Fast Idle
i have tried to disconnest it and it is supposed to die but it doesn't. It is a new IAC also.
Old Jan 10, 2003 | 09:49 PM
Ken00's Avatar
Ken00
Fast Idle
They don't always die with the IAC disconnected but you should see an rpm drop. Have you checked the base idle speed which is usually a few hundred below the speed with the IAC. I would also double check for vacuum leaks, check for codes, clean the MAF and test the ECT.
Old Jan 10, 2003 | 09:58 PM
WXboy's Avatar
WXboy
Fast Idle
My truck does this too. I truly believe it's one reason why my gas mileage sucks. But too bad it can't be adjusted...because the entire freaking truck is computer controlled now.
Old Jan 10, 2003 | 09:59 PM
Ken00's Avatar
Ken00
Fast Idle
Old Jan 10, 2003 | 10:13 PM
Ken00's Avatar
Ken00
Fast Idle
>controlled now.
I don't think the IAC would cause a gas mileage problem, I would suspect an O2, dirty MAF or bad ECT problem might be the cause. What kind of mileage are you getting and what are you driving habits. I get bad mileage since I drive only a few miles each trip and it never goes into closed loop.
Old Jan 10, 2003 | 11:35 PM
Racerguy's Avatar
Racerguy
Fast Idle
What vacuum leaks did you fix? It is very common for the fuel rail gaskets to leak. Both the gasket on top and the one under it.
Old Feb 5, 2003 | 05:44 PM
Sparkyboy's Avatar
Sparkyboy
Fast Idle
Have you checked for engine codes?
Old Feb 6, 2003 | 04:03 PM
amp17757's Avatar
amp17757
Fast Idle
This may sound a little overly simplistic ... it's been discussed in many posts & replies ... have you checked your TPS (throttle position sensor)?? When you said it drops to about 1200 or 1300, then to 1000 a couple seconds later, that sounds like the behavior of the TPS & related equipment. If you make sure all the connectors & stuff are clean & functioning properly, that would be a good starting point. By the way, I don't know how much Ford has changed the TPS over the years. My '85 has a TPS, and any manuals I read say that idle speed is "computer controlled" and "non adjustable", when what they really mean is that you AREN'T SUPPOSED TO ADJUST THEM BY LAW (emmissions regulations). Mine is indeed FULLY ADJUSTABLE, and I have adjusted it to my liking. Are newer ones adjustable??
Old Feb 6, 2003 | 04:55 PM
Bob Ayers's Avatar
Bob Ayers
Fast Idle
Have you checked the lower intake bolts and/or gaskets?
The lower intake was known to loosen up on the vintage
4.0L that you have.....
Old Jul 5, 2005 | 07:41 PM
coryrhonda's Avatar
coryrhonda
unplug the mass air flow sensor if it has one, not sure if that year had one or not, and start it up and let idle. remove the rubber air inlet tube from the throttle body and close off the throttlebody opening with a piece of stiff cardboard. motor should die instantly and pull hard on card board, if not you got a vacuum leak. Many times they can be a bugger to find,exspecally if not an external leak. Leaks from stuff like purge solenoids and brake boosters can let air in past the iac and throttle plate.
Old Jul 6, 2005 | 07:20 PM
Ken00's Avatar
Ken00
Keep in mind this thread is over two years old.
Old Jul 6, 2005 | 07:22 PM
jimw411's Avatar
jimw411
It's been so long now, his engine has already wore out and been replaced.
