Sponsored by: Auxito
2-4 drop concerns
Old Oct 14, 2004 | 03:09 AM
zachmasaki's Avatar
zachmasaki
2-4 drop concerns
I just put a 2/4 DJM drop on my truck. I installed the front coils and everything went fine except for the front shocks needed to be changed afterwards. Yesterday the back was finished, and now I am getting a very hard and loud vibration throughout the truck at exactly 55 to 60 MPH, it gets worse if I floor it but only between that same speed. The tires are not rubbing. I just cannot think of what it could be. Thanks in advance for your help
Old Oct 14, 2004 | 04:36 AM
Savorino's Avatar
Savorino
Spring isolaters?
Did you use isolators on the tops of the springs?
Sav
Old Oct 14, 2004 | 08:40 AM
truckfanactic's Avatar
truckfanactic
It could have to do with your pinion angle (rearend angle). Check to make sure that it is at an upward angle lined up with the driveshaft.
