LLS 00 Navi
Old Oct 14, 2004 | 12:05 AM
dadamaja's Avatar
dadamaja
LLS 00 Navi
Ok,
I have been going through the forum for about 2 hours now and have seen alot of similarities to my problem. The rear went down one day all of the sudden with no warning light or anything. I have since manully pump it back up (by jumping the wires on the compressor) so I know the pump is good. Using a circuit tester, I attempted to see if there is a signal coming from the control unit to the relay to tell the pump to come on. I turned the ignition off and on, closed doors and no signal. Is that normal or do I need a new level sensor or control unit? Is there a way to confirm that a signal is coming from the control unit? Any help would be greatly appreciated.
Old Oct 14, 2004 | 12:09 AM
dadamaja's Avatar
dadamaja
O' Yea, by the way if anyone is interested, I have the wiring diagram for the LLS in pdf format. If you would like a copy, let me know and I can send it to you.
Old Oct 15, 2004 | 06:49 PM
Crypto65's Avatar
Crypto65
If you get around to it send it to Eagle971 @ aol.com Thanks
