1978 - 1996 Big Bronco
87 push button 4x4 switch?
Old Oct 13, 2004 | 08:32 PM
schrubmeister's Avatar
schrubmeister
i'm buying an 87 eb that has the push button 4x4 and i was wondering if i could switch to a standard shift lever, my 88 had the lever and i felt much better knowing it was in gear, can it be switched?
mike
01 S-Crew 4x4
87 EB Bronco
Old Oct 13, 2004 | 09:57 PM
Lookinfurfun's Avatar
Lookinfurfun
Sure can. Just make sure you get all the linkage to go with it. If you pull back the carpet, you will see where it goes through the floor.
Get it from a Bronco and not a pick-up truck though.
Old Oct 17, 2004 | 08:27 PM
schrubmeister
87 push button switch
thanks for the info i just bought the bronco thursday nite and don't really like the push button and i also found out it's an 88 (the man didn't know what he had when i talked to him). do you happen to know what the clicking noise is when i push the 4x4 button ? it's going into 4 wd but making a weird clicking and the headlights flicker slightly, i figured it was the solenoid pulling in the transfer case but i don't know?
