Lights On Buzzer
Old 10-13-2004, 07:49 PM
plapczynski's Avatar
plapczynski
plapczynski is offline
Lights On Buzzer
Hi, I have a 93 F150 XL. Should my truck buzz when I leave the lights on or keys in the ignition?
Thanks,
Paul
Old 10-13-2004, 07:53 PM
Twitche's Avatar
Twitche
Twitche is offline
I have an 89 that has no buzzer. Maybe they never put them in. My 86 didn't have one either.
Old 10-13-2004, 10:59 PM
aikigod's Avatar
aikigod
aikigod is offline
My '92 chimes when I leave the lights on or the key in the ignition and open the door (actually, my ignition cylinder is broken, so it chimes even when there is no key in the cylinder, until I jiggle it).
Old 10-14-2004, 07:59 AM
GermanGuy's Avatar
GermanGuy
GermanGuy is offline
I agree with aikigod, the chime should sound when you open the driver side door (door jamb switch) with the lights on or the key in the ignition cylinder (this is what the shop manual states). You should find the chime module under the dash left side from the ash tray most towards the firewall. Do the cab lights come on when you open the driver door? If not you may check the driver side door jamb switch.
LoL Dieter
Old 10-14-2004, 10:43 AM
dan1101's Avatar
dan1101
dan1101 is offline
My 95 doesn't chime, it buzzes loudly. I don't think it buzzes when the lights are left on though.
My 90 Mustang used to chime slowly if you left the keys in (which I do a lot of times), but chimed faster if you left the lights on. That was pretty handy.
Old 10-14-2004, 06:26 PM
Andyman8282's Avatar
Andyman8282
Andyman8282 is offline
XL's Buzz, XLT's Chime. Atleast that's the way I've always understood it. For many people the first thing they do is either pull the fuse for the buzzer, or disable it somehow, usually by cutting a wire or two. Maybe you'll get lucky and it'll be as simple as replacing the fuse.
This is assuming you either 1. just bought the truck or 2. Have owned the truck since new, and read/heard something about how the truck "should" buzz.
Old 10-14-2004, 06:43 PM
jmurphy_5's Avatar
jmurphy_5
jmurphy_5 is offline
i have 93 f-150 and it dos'nt chime. but i wish it did for the lights. killed battery
Old 10-14-2004, 06:47 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
FghtinIrshNvrDie is offline
I've got an XLT. I think my chime..er is broken or something. My ignition cylindar is also shot. It could be a combo, of course, when my door's open, it still doesn't do anything. I'm not terribly interested in fixing either of them.
Ryan
