hi i a new excursion owner and seem to have problems with the front end bottoming. have seen many posts but some have diesels and i would assume they would be more front heavy.
so if cost isent an issue what is the best fix? i primarly use this truck for work and towing around 8500lb trailer.
i'm thinking that maybe f-250 springs all around would this stance be level or do i need 350 blocks?
seems search is down so please help
thanks
pete
I know there is a post in here somewhere, and if I recall correctly, some had their rubber boots (bumpers) underneath the springs cut off or at least shortened...
I'll try to locate the exact post and will let you know if I find it...
