High RPMs at 75 MPH
Old Oct 13, 2004 | 05:06 PM
djf48's Avatar
djf48
High RPMs at 75 MPH
I'm running at about 3000rpms at 75 mph, is that normal? I have a '97 F250, 5 speed. I'm not sure what the tranny is geared at, but it really sucks the fuel on the highway!
Old Oct 13, 2004 | 05:14 PM
Domino'sDiesel's Avatar
Domino'sDiesel
I have a 96 250 5 speed, and i'm running about 27 to 28 hundred RPM's at 75 MPH. I'm sure you have the same rear as I do, 4.10 limited slip which is axle code c-5, located on the driver's side door jam. One way to improve this slightly is larger tires. Another way is only to swap out the rear for 3.55's.
Old Oct 13, 2004 | 06:26 PM
77hiboyboy's Avatar
77hiboyboy
I would swap to 3.55's, we had a 97 4x4 crewcab 350 with 4:10's and they sucked, a neighbor could tow just as mutch as us with his 3:55's. It will make life alot nicer.
