Sponsored by: Real Truck
Lift kit difficulty
Old Oct 13, 2004 | 12:36 PM
77hiboyboy's Avatar
77hiboyboy
Lift kit difficulty
I found a guy trying to sell a superduty on a small lot and he is about to wholesale it, and If he can't get it sold in the next couple of days he will let me swap my stock stuff for his lift, but its a 99. Is there any difference?? I think its a 4 inch. How involving is a lift??
Old Oct 13, 2004 | 12:49 PM
02superstroker's Avatar
02superstroker
what year is yours? As long as it is a late 99 you should be fine. The trac bar setup was changed around that time.
The axle tubes could also be different diameters.
Old Oct 13, 2004 | 06:17 PM
77hiboyboy's Avatar
77hiboyboy
00, can I tell by the vin if it is different??
Old Oct 13, 2004 | 07:22 PM
02superstroker
Good Question! But unfortunately I don't have an answer
The trac bar you will be able to see the difference (i think). I am not sure how you would go about measuring the axle tubes... I guess you could measure the circumferance with a piece of string or wire or something... or if you got new u-bolts you wouldn't have to worry about it at all.
Old Oct 13, 2004 | 07:29 PM
DCSpecial's Avatar
DCSpecial
You can check the build date of the '99, if I remember correclty the cutoff for an early '99 is 3/21/99.
I think the early '99s had smaller trac bar bolts, a different pitman arm, and possibly square u-bolts (but I'd get new u-bolts anyway).....at least that's what I seem to remember.
Old Oct 13, 2004 | 09:34 PM
jetjock16's Avatar
jetjock16
the trac bar bolts are WAY SMALLER.. it will be obvious.. there lil bitty things
Old Oct 14, 2004 | 03:45 PM
99 sd v10's Avatar
99 sd v10
Hey, I have an early 99.
You're starting to give me a complex here.
I'm feeling undersized.
I believe at some point they went from d50 to d60 also. I don't know what that meens will be different on the diff.
Old Oct 14, 2004 | 07:00 PM
77hiboyboy's Avatar
77hiboyboy
I got him to send me a pic, does this look like a late 99??
