Where is PCV on 97 Explorer
Old Oct 13, 2004 | 07:55 AM
gibsonj's Avatar
gibsonj
I have a 97 Explorer, 4.0 V6 SOHC. Can anyone tell me where the PCV is located on this engine? Not in the usual spots---on valve covers. Thanks.
Old Oct 13, 2004 | 09:39 PM
98xlt's Avatar
98xlt
in between firewall and engine, near top of engine. It sits in a rubber tube and also has a "Y" out its top, going into two smaller hoses leading to either side of the engine.
Old Oct 14, 2004 | 07:36 AM
gibsonj's Avatar
gibsonj
Thanks---must be nearly impossible to see. Do you have to remove any of the intake assembly to get at it to change, or just feel your way through it?
Old Oct 15, 2004 | 12:28 AM
98xlt's Avatar
98xlt
it might help a teeny bit to remove the hard plastic shroud on top of the engine, but for the most part, if you look with a flashlight from the passenger side, you can see it and reach it
Old Oct 15, 2004 | 07:22 AM
gibsonj's Avatar
gibsonj
Thanks a lot. Knew I could count on this group for an answer!
