timing a 1982 351w
Old Oct 12, 2004 | 09:04 PM
superhooperduty's Avatar
superhooperduty
timing a 1982 351w
can anyone tell me the correct timing for a 82 f150 with a 351 w? info tags missing from engine area. thanks!
Old Oct 13, 2004 | 10:49 AM
desperado_18_2000's Avatar
desperado_18_2000
The engine should be Timed anywhere from 8-12 degrees before top dead center.
if you don't have the firing order its 1-3-7-2-6-5-4-8.
Old Oct 13, 2004 | 09:09 PM
superhooperduty
1982 351 timing
thanks, seems if i use retard it more than 14 degrees btc it runs a lot better tho. i hve build this engine using lots of aftermarket parts, pistons, heads, cam and lifters etc, maybe this is the difference?
Old Oct 14, 2004 | 12:01 AM
desperado_18_2000
Hm, whats the compression on this monster? You may have to pull some timing out of it to get it started. But with the timing that far retarded the engine shouldn't even run.
Hope you get it fixed, it sounds like a beast. Good luck to ya!
Old Oct 14, 2004 | 02:59 PM
superhooperduty
351 W Timing
The Compression Ratio Is Supposed To Be Very Close To 9.5/1. It Starts Really Well. Runs Quite Smoth, Except It Has A Bog When I Tromp On The Gas, Its Been A Real Trial Getting The Thing To This Stage, Last Night I Took It Out To Road Test It And Other Than The Bog Off The Line It Hauls Compared To The Efi 302 That Was In The Truck, Now If I Can Get The "baunmanator Tcs" Unit To Work Correctly I'd Have This Puppy Wrapped Up For This Year At Least. Thanks Again.
