built 351W power
The specs are as followed:
351 windsor 2 bolt block (bored .030 over-now 357.29 cubic inches)
rebuilt and reworked heads with 1.94/1.55 intake/exhaust valves
edelbrock cam and lifters(280 degree duration, .448/.472 lift LCA=107 LS=112
Edelbrock performer intake manifold
Edelbrock 4 bbl 1406 carburetor (flows about 620 cfm)
1" open plastic carb spacer
14"X3" K&N air filter with substack
Hooker full length competition headers
dual 2.5" 40's series mufflers (no cats, no EGR, and no smog pump)
2.5" H pipe
I am not sure of the output of this setup, give me your best guess of the power at the crank, it will be greatly appreciated.(I don't have the resources for dyno time)
If at all possible you might consider going with another camshaft, comp and crane have newer camshafts that can give you more hp/torque and vacuum than that camshaft.
If you have to have the performer grind, you might wanna contact paw performance and use one of their cams, they have a grind that is identical to the performer, $50 for the cam and $40 for the lifters...It is my understanding that it is the same camshaft...using a generic name.
who knows? Good luck
2.5" H pipe
erformer rpm cam ,performer rpm aluminum heads the intake and exhaust valve size 2.020 /1.600, holley 750 , acuetune geardrive,roller rockers,performer rpm intake,2in spacer for carb,billet crank,1-3/4in shortyheaders to a 3in colletor ,h-pipe 3in,flowmaster,compression 10:1, msd 6al box,msd distrib,34 total timming,no ac no ps no smog pump, 2-1/2 cowlhood. in a 85 foxbody 3-door /t-5 trans /8.8rearend right now running 2.73 gears getting over 400hp /412ft/lbs.so i would say that you should be in the 300 range noprob
Best of luck in your build!
