test Drive Used Vehicle
Old Oct 12, 2004 | 06:00 PM
damone's Avatar
damone
What should I look for. How should I drive it.
Looking at 2001 Excursion 7.3L
Old Oct 12, 2004 | 06:14 PM
Tell3131's Avatar
Tell3131
Drive it like you stole it!!!!!!!!! Or how you normally drive it. Check for any weird sounds. If you have a friend that is a mechanic, have them look at it. Try to get the history of the vehicle, # of owners, warranty work, carfax (although this isn't perfect). Buying a used car is a gamble, but you can limit your risks with a little bit of work.
Have the owner show you maintenance records or at least where maintenance was done at.
Old Oct 12, 2004 | 09:58 PM
huntercgr's Avatar
huntercgr
Also try to have a dealer run an Oasis report. That should tell you anything a dealer has done to it.
Old Oct 12, 2004 | 10:12 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum. The new vehicle forum is for NEW vehicle dealer relations questions.
Old Oct 12, 2004 | 10:59 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
The OASIS report should tell you everything you need to know. If it's well taken care of, go for it. A well maintained vehicle won't give you as much trouble as one with a "spotty" maintenance record.
Old Oct 12, 2004 | 11:18 PM
Myckel's Avatar
Myckel
You can take it to AAA and have them check everything in engine and the suspention costs about 70.-.
Myckel
Old Oct 14, 2004 | 03:04 PM
SilentlySoaring's Avatar
SilentlySoaring
So, AAA will do the checks for $70, huh. Well, that's less than the 'per hour' rates at some shops. I may just take mine by for a $70 checkup. lol
